jcniest5 Posted July 10, 2005 Share Posted July 10, 2005 Hi all. Long time no post. Just put in a new/used tranny, now my right/rear wheel locked when driven, what could be the problem? Wrong tranny? My old tranny has TZ102ZA1AA, the new one has TZ102ZA2AA. The only difference between the two is the 2 (new) vs. 1 (my old one). However, that number, according to a guide posted here or somewhere in a link is just to typify the year. Could it be that the gear ratio is different, which doesn't seem to be the case as the 102 typifies the gear ratio (also according to a guide). If anyone at all can direct me to the correct solution, I will appreciate him/her so much. I just finished putting it together and it's so much work putting into it already, if it's not fixable, then I guess I will just junk the whole car as I'm running out of patience. Thank you so very much in advance... Link to comment Share on other sites More sharing options...
jcniest5 Posted July 10, 2005 Author Share Posted July 10, 2005 Update: Put in a new Tranny computer and the tranny is working okay now. With the old computer, if I put in the fuse and disable the rear wheel drive and make it FWD, it works okay also. Also, just wondering if the two letters after the tranny number makes any difference. The old tranny has a JS and the new one has MH. Do these letter signify anything? Link to comment Share on other sites More sharing options...
piloto Posted September 2, 2005 Share Posted September 2, 2005 Hello. I think you have different gear ratio on front a rear diff. I have the same problem and I'm looking for a new rear diff with the correct gear ratio. Hi all. Long time no post. Just put in a new/used tranny, now my right/rear wheel locked when driven, what could be the problem? Wrong tranny? My old tranny has TZ102ZA1AA, the new one has TZ102ZA2AA. The only difference between the two is the 2 (new) vs. 1 (my old one). However, that number, according to a guide posted here or somewhere in a link is just to typify the year. Could it be that the gear ratio is different, which doesn't seem to be the case as the 102 typifies the gear ratio (also according to a guide). If anyone at all can direct me to the correct solution, I will appreciate him/her so much. I just finished putting it together and it's so much work putting into it already, if it's not fixable, then I guess I will just junk the whole car as I'm running out of patience. Thank you so very much in advance... Link to comment Share on other sites More sharing options...
jcniest5 Posted September 7, 2005 Author Share Posted September 7, 2005 I've disabled the rear wheel (put it in FWD only - inserted the fuse) and so far it's working nicely for the past two months or so. Hope nothing is wrong with a long term (or even permanent) FWD operation, is there? Link to comment Share on other sites More sharing options...
