July 13, 200520 yr The Haynes manual says I have to pull the timing belt to change the crank sensor on my 1991 Legacy, non turbo. Other people say it is easy to change. does the timing belt need to be removed? Thanks.
July 13, 200520 yr No, the timing belt does not have to be removed as far as I remember. The crankshaft sensor mounts to the top of the oil pump with a single bolt. It should be accessible when you remove the alternator. Matt
July 13, 200520 yr Author Thanks. Actually, I guess it was the Chilton's manual that said remove timing belt. Glad to know its not that hard.
July 14, 200520 yr Ditch the crappy manuals and d/l the factory one from me. http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/ It's for the 92, however most of the stuff is the same.
July 14, 200520 yr Author I tried Josh. It locked up my computer! Will try again later. The aftermarket manuals truly suck.
July 14, 200520 yr Does the link work? You need to RIGHT CLICK AND SAVE AS the pdf document. Do NOT try and open it from the web.
