July 14, 200520 yr Hay if i get a hold of an EA82T, will it bolt straight in other than the running of the wiring?? If not would it still be easer to do than the EJ20T swap? Thanks for all the help
July 14, 200520 yr Hay if i get a hold of an EA82T, will it bolt straight in other than the running of the wiring?? If not would it still be easer to do than the EJ20T swap? Thanks for all the help Well either one will pretty much bolt up, the EJ20G (not T) will require a bit more fabrication (rear tranny mount), both will require some re-wiring, the EJ probably more then the EA. But if you are looking for power AND reliability, the EJ20G is the only way to go.
July 16, 200520 yr Author What do you mean EJ20G? What about the EJ25? Here in oz we dont seem to have the HG problems with the 25's that the people over seas seem to be havin.
