help tps wiring and fuel pump relay ect
seems the tps i was using for my orginal measquirt install has shorted out and is very useless now its all thats holding me up on making the rx run
so i have the old one from the 85 rx but i need the pinouts for it
what color wires are ground signal and +volt
its a 3 wire unit no idle/wot switch
otherwise everything else is all wired up in teh rx and seems to check out just need a good tps to put on it so i can start it up
also need to know wich wires under the hood at the connector are for the oil psi gauge and the temp gauge
plus how the tach is triggered
