July 27, 200520 yr Hey, quick question. We just picked up a 88 turbo wagon that uses the hot wire MAF, question is can I put it into my '86 XT turbo that uses the flapper door (direct swap)? It seems as though that'd be an advantage having it. Any other issues/gremlins that might need to be addressed? Matty ps - havent gotten a chance to get home to finish the wiring on the 5th injector, will update as soon as it happens tho
July 27, 200520 yr I would say no. But if you swapped the complete intakes and engine wiring harnesses and maybe the distributors, I see no reason why that would not work.
