July 27, 200520 yr I have a 93 Justy with 103,000 miles. It has a hesitaion that doesn't appear to be tied to RPM's. I changed the Fuel Pump, but that wasn't it. It never does it at idle, but at every speed it does. Very intermittent, and getting worse. I have had three tune-ups since this started with no improvement.
July 28, 200520 yr Fuel Injection or carb? Since its a 93 I assume FI... I would try replaceing the ECU coolant temp sensor or atleast checking to make sure of the connection and function. If not that...possibly the MAF or MAP's operation and connection.
July 28, 200520 yr Author Fuel Injection or carb? Since its a 93 I assume FI... I would try replaceing the ECU coolant temp sensor or atleast checking to make sure of the connection and function. If not that...possibly the MAF or MAP's operation and connection. Thanks, Its Fuel Injection
