ea82/ea82t injector flow rates
i had it written down but lost the paper
so does anyone know the flow rates for the ea82/ea82t injectors
looks like the injectors in my spider intake are the same as my ea82t injectors
Well well well you might be in luck oddcomp. I just picked up a fuel pump from the junkyard from an xt6 that WORKS!&!#$*#. I tried one off of a xt turbo but no luck it was crap. Currently I have injectors for an XT6, XT4 turbo, 280zx 280zx turbo and a 240zx turbo. I am going to be building a flow bench this weekend to see what each of them run. If I can remember I have a full set for each of these cars so I am going to test them all hooked together each set at a time. I will pick up a set of EA82 injectors on friday so I can run those one my bench also. I FREAKEN CAN'T WAIT!!!!!
I will be posting my findings on this Thread though sorry buddy.
http://www.ultimatesubaru.org/forum/showthread.php?t=26375&page=5&pp=10
Oh ya Odd if you havent seen this I have fit the 280ZXT injectors in the XT6 fuel rail with minor modification. With no modification they should have no problems fitting a XT turbo, as far as a N/A EA82 I need to look at the fuel lines and see how they are setup.
I have to check but I could have swore that the ER27 and EA82T fuel plumbing was the same ie.. pump, injectors and such. I will let you guys know the difference I am going to be setting up the new flow bench and we will have confirmed numbers.
yeah my megasquirt setup is using the 180 cc numbers to base its fueling off of..
but i would like confirmed numbers..
YO ODD post a picture of the injectors you have so I can compair them to what I have in my arsonal. Thanks buddy!
