August 1, 200520 yr For an EA82 engine, the O-ring that goes in the oil passage between the cam carrier and the head. My NAPA dealer says it's a "special" gasket and only the dealer has it. It's hard to have a job and stop into the dealer with their limited hours. Does anyone else carry this part? Part Number? Thanks, Steve
August 1, 200520 yr I just got this part from the dealer. It's listed in their computers as an 'o-ring' (I know, very original I can get you the subaru part number tonight when I get back home.
August 1, 200520 yr You can order online with several Subaru dealers. Some will even give an internet discount. https://www.1stsubaruparts.com/ http://www.allsubaru.com/ They will deliver to your door.
August 1, 200520 yr For an EA82 engine, the O-ring that goes in the oil passage between the cam carrier and the head. My NAPA dealer says it's a "special" gasket and only the dealer has it. It's hard to have a job and stop into the dealer with their limited hours. Does anyone else carry this part? Part Number? Thanks, Steve If its the O-Ring that is in the second picture of... http://homepage.powerup.com.au/~cam..._lifter_fix.htm i just purchased that from the dealer... subaru part # 13089AA010 ...and it was $2.95 i figured i didnt want to deal with getting the wrong one... since ive read so many people have had issues with it. hope it helps! Luigi
August 1, 200520 yr I just took the old o-ring parts into a parts store, matched it up to a high temp o-ring they had, and used it. Worked fine until I sold the car, and I haven't heard any complaints about huge oil puddles, so I assume it's still working. -=Russ=-
