August 9, 200520 yr Got an 84 GL 4sp D/R I was checking out the fluids and found the tranny oil was WAY over filled! It measured about an inch and a half OVER the full mark on the dip stick. Is this going to be a problem? and... Is there a drain plug to get rid of some oil, like the diff has? I know I can pull the drive line and get a 90w shower and I could probably pump it out... But is there an easier way...? Thanks Glenn, 82 SubaruHummer 84 GL Wagon 01 Forester
August 9, 200520 yr It shouldnt have hurt anything and you can drain it thru the large drain plug, its probably a 21MM or 22MM plug dead center (widthwise) in the transmission near the front.
