I am new here and I have question about my 1992 legacy 2.0 4×4 (european market :)).
Every time when i want to start my legacy at morning (cold start), car start without a problem but after a few seconds die? - but if I step a little on throtle is fine. The same problem I had on may old legacy 2.0 GL 2WD.
There is no Check engine light signal.
Thank you for your answer
When I start the engine rpm goes on 1300 rpm and the usualy back to zero and motor dies. If I touch throtlle for second and leave then car works OK.
The fuel is OK, sparks are new. Only trouble code 35 I get 1 month ago and I replaced Canister purge solenoid... But the problem is still there.
As Josh mentioned, a weak coolant temperature sensor can cause some weird idle/stall problems--replacing mine made a great difference. How about PCV? Idle Air Control Valve? Throttle cable? Fuel filter? Air filter?
Wish I could be of more help. Good luck.
