O.K. this is a new one. I need your help with some Swedish translation. My '96 OBW was in the shop for a check engine light problem. In the process, the mechanic stated that I needed to order and replace something that I translate to a cam axle sensor (kamaxel givare in Swedish). Is there something that goes by roughly this name? It was bad but easy to replace.
Thanks!
Sweden
Thanks!
Sweden
Probably a cam angle sensor, that sounds close. This article may be of help:
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-78a.htm
I will assume that they are the same and contact them here for a price.
Thanks!
By the way, I had a great time in Copenhagen last week. The problem was the 4-5 hrs of commuting each day. The bomb scare (forgotten backpack) was also a problem at Osterport. I didn't see any Imprezas flying down the road past me though...
