help 4 an 97 outback
My outback has a leak in the heater box and fumes are coming in the vents. how do I get to the heaterbox and fix it ? If you can help me please do.
Regardes Sha
The heater box is behind the center of the dash. I believe you have to pull the complete dash which is a job but not too bad.
disconnect the battery
Lower the steering column
Disconnect the harness at the left and right sides
Pull the bolts at the sides of the dash
Pull the bolts at the center bottom of the dash
Pull the bolst along the top
Lift the dash up and out
Now you will have access to the heater box in the center
pull the heater hoses from the engine compartment
pull the heater box and core
Replace in the reverse order
Don't forget you have two air bags Folllow the book so you don't set them off.
