September 13, 200520 yr anyone have the fully extended/fully compressed length of the rear 4wd shock off an Gen3 Leone A10 or A11? 2wd will work as well. NO XT shocks please! thanks
September 13, 200520 yr I have a rear shock from my RX here, still fully assembled- it measures just a tiny bit over 18 3/4 inches from the top of the top nut to the center of the bottom bolt hole. I measured from the top of the nut instead of the very tip of the shaft, because that little tab at the end that aids in disassembly of the shock is snapped off- hence the part still being assembled.
