September 21, 200520 yr Ok, during the summer I bought a '77 Wagon. Cleaned and tuned it up. drove it from Roseburg to Bend. It has a problem with spuddering, it's like it's running out of gas. It happens after you get on it a little, or if you are going up a hill. If it starts to spit and spudder I can turn the key off and then back on and it some times works. could it be the Valves? Another thing is it will only run on Prem. gas, and has gone through two fuel pumps. I don't know what to do. Another question will a DL bumper fit on the 77 GL? The Dl has two round head lights and my '77 has four. I'm not sure of the DL's year.
September 21, 200520 yr Check the timing lately? Check all vacuum lines too. Did you have a lot of rust come out when you did the fuel pumps? If both cars are 2wd then I think the bumper will fit.And they need to both be Stage I or II.
September 21, 200520 yr Author no rust, no vacume leaks, and the timing is almost dead on, but i do need to tweak it a bit. my 77 is 4wd stage 2 the other is fwd and stage 1.
