Ragnor Posted September 27, 2005 Share Posted September 27, 2005 I busted the tranny out of my brat a while back. I have been told that 4wd unit will bolt up on a 2wd trany from matching years . Can anyone confirm this. Curent trans 4spd. is out of an 85 Brat , replacement is 5spd. out of 86 GL. Mounting is not an issue, just the bolt on compatability. Time to hunt! must have Brat! Quote Link to comment Share on other sites More sharing options...
jeffroid Posted September 28, 2005 Share Posted September 28, 2005 I'm not the best to be answering this question, but since nobody else has ponied up, I'll suggest that the 2WD tranny will bolt right up to your Brat without issue. The flywheel/clutch might be smaller in diameter on the 2WD than the 4WD, but either should work. Why do you want to turn your Brat into a 2WD vehicle ? ? ? I guess if you don't need the 4WD you would end up with better gearing with the 5 speed. Quote Link to comment Share on other sites More sharing options...
Ross Posted September 28, 2005 Share Posted September 28, 2005 I think he means he want to bolt the transfer case from a 4wd box onto a 2wd box. I dont actually know, but i suspect it wont work. Quote Link to comment Share on other sites More sharing options...
Ragnor Posted September 28, 2005 Author Share Posted September 28, 2005 Yep the idea is to mount the 4wd unit onto the formerly 2wd tranny, However now that you mention it, I might end up just having a 2wd brat for a while if it wont work. Mostly I never spend money I dont have to , since I'd dont have any and if I did I'd much rather spend it on misc. hunting supplies. Quote Link to comment Share on other sites More sharing options...
