engine misses at startup
hello,new to this site. 91 legacy l 2.2 sw awd. this car will miss at startup and check engine light will come on for about 5 seconds and go out. if you go ahead and drive it goes away and may not do it again for 15 starts. any ideas?. thanks. ed
Check the ECU codes. Instructions on how to pull the codes can be found on my site under notes & tips, engine related.
Once you get the codes pulled, post back, and we can try and troubleshoot from there.
