How to get too P/S res.?
OK, in my Mom's '03 GT Legacy sedan the intake for the engine is RIGHT over the cap for the P/S tank! I guess I have to remove the intake. Also how do I get the cap off? Does it pull stright-up or spin off?
With the 30k service I like to suck out the old ATF and put new Dextron III in. Is there a filter on this system?
Should the PCV valve be replaced at 30k as well on the EJ253??
OK, so it does un screw, it tried turning it an the cap just spun around and did not seem to come loose?? It is hard to get too under the air intake on a '03 GT!
