Humm,, maybe the problem is resolution and file size..
for example,,
An image that is 6"x6" @ 72dpi (dots per inch) might only be 100k (kilobytes)
while an image at 3"x"3" @ 300dpi might well be over 500k
So I would make sure that in some "photo editor" on your computer to make sure the image is about 75dpi or so, then you can make the image bigger at that resolution. and save it as a compressed .jpeg this will make the file size even smaller.
Color also adds to the file size. if you can drop the image to 16 colors or
(VGA) that will make the file size smaller.
hope that helps. :)
