compression 8.5,9,8.5,9 bar(1,2,3,4)..is a good/bad compression
-this values whas read with hot engine....:cool:
Thanks.:drunk:
According to the FSM standard compression is 11.0-11.8 bar
The lower service limit is 9.0-9.8 depending on cranking speed
Subaru reccomends no more than 2 bar, or 28 PSI variation between cylinders
It does show an (other) category, which could be MPFI or Carby, i'm not sure, but if its MPFI the lower service limit is 8.5-9.3
Which means you should be fine, but like the rest of us, a new set of rings wouldn't hurt
* This is from the 89 XT FSM
