trooper II alum rims
anyone running these rims 15x6 w/ 235/75r15s?
I'm considering it using the Steel Trooper rims. The offset should be the same. I was going to use a smaller tire though?
Are you planning on drilling the rims or the hubs?
Glenn,
82 SubaruHummer--Custom 12" rims
84 GL Mad Max--Needs a lift before it gets bigger tires.
01 Forester--No mods till the warrantee is gone...
i wdill re drill the hubs then if i ever want to chenge rims it is another 6 bolt 15" rim or tap in the original studs in factory spots
