October 19, 200520 yr anyone running these rims 15x6 w/ 235/75r15s? I'm considering it using the Steel Trooper rims. The offset should be the same. I was going to use a smaller tire though? Are you planning on drilling the rims or the hubs? Glenn, 82 SubaruHummer--Custom 12" rims 84 GL Mad Max--Needs a lift before it gets bigger tires. 01 Forester--No mods till the warrantee is gone...
October 19, 200520 yr Author i wdill re drill the hubs then if i ever want to chenge rims it is another 6 bolt 15" rim or tap in the original studs in factory spots
