lifting my subbie
95 super subbie
Go to a junk yard and get the struts. You can also lift the vehicle by taking the factory lift out of the Outback (use the struts and lift). Or you can just go with the struts and put a little extra strain on your axles and achieve more clearance. We make a lift for your vehicle so if you put the outback struts on you can get the lift and go big. For cheapness sake and depending on how hard you are going to 4x you may just want to go with OB struts. I don't think you'll have to worry about the camber because the front and rear of the OB are adjustable.
i have a 95 legacy 5 speed can i put outback stuts on it to give it more ground clearnce and is there any thing esle i would need to do like alightment right?
