October 31, 200520 yr what seats can be adapted into gen 1`s that would be a fairly easy swap?mine are shot, and the imp seats i have are way too wide.
October 31, 200520 yr wide as in don't have room for the center tunnel? or wide as in bolt pattern for the mounts? if it's the latter what I did to fit some gen 3 seats in is use some bar stock that I drilled and tapped to fit the original seat mounts/sliders and drilled the other holes for the seat itself and also had it offset so it lined up with the steering wheel and also get away from the tranny tunnel this is in a 76 4wd wagon btw
