Heatercore gurgle?!
he probably means by squeezing the heater core line with his hand. The other method I've used with success is to find a way to get the nose of the car as high up in the air as you can, and let it run for a little while.
This can either be done by driving up a small hill, parking on ramps, etc. This is my preferred method to bleed the cooling system after doing a flush also.
What Subarian said! icon7.gifCouldn't think of the right word - pump, squeeze, massage, milk... Upper radiator hose - squeeze, release, repeat. Add coolant if necessary, repeat process.
how did you go about pumping on a line. bike pump or something?
