jrski Posted November 1, 2005 Share Posted November 1, 2005 Fro two consecutive days my cruise contrl suddenly cut out after about 20 minutes. The dash switch light goes out ans is totally unfunctional until I shut engine off and restart. Anybody have this happen to them? Quote Link to comment Share on other sites More sharing options...
jrski Posted November 1, 2005 Author Share Posted November 1, 2005 Forgot to add: I have a 2003 Outback w/ 43K miles Fro two consecutive days my cruise contrl suddenly cut out after about 20 minutes. The dash switch light goes out ans is totally unfunctional until I shut engine off and restart. Anybody have this happen to them? Quote Link to comment Share on other sites More sharing options...
Cougar Posted November 1, 2005 Share Posted November 1, 2005 Hopefully the problem is just do to the switch itself. If it is the switch I would think you could reset the unit by turning the cruise control off and back on. If that doesn't work then check the brake and clutch switches (if you have a MT). See if hitting the brake will cause the symtom you have. I would think that the unit shouldn't turn off the cruise power indicator. If those switches don't give you the right symptoms then the next choice may be the cruise control actuator in the engine compartment. The last choice is the cruise control module behind the dash. Quote Link to comment Share on other sites More sharing options...
