air to coil suspension
i need to swap my front air springs to normal struts, and was wondering what i would need(other than the struts themselves) to make the job work, it is a 4wd car, and the pass front air spring is shot,so the drivers front will be on sale here once i get the swap done.
any ideas or interest plz let me know
pics avail soon
omniman69@hotmail.com
All you need is the complete struts (w/ spring and strut top) from the donor car. You'll also want to disable the air suspension compressor in case it keeps trying to fill up the nonexistant air struts.
parting off a car the entire strut assembly is all you need.
if buting new strits you will need also the spring and the strut cap
both front and rears are direct bolt ins.
disconnect the compressor or pull its fuse or it will run constantly stressing the alternator
