1988 subura
Hello
I'm looking for where the Auxiliary fan switch is located on a 1988 Subura XT6 And where the water temp sender is located if you could let me kmow because i'm not sure what the part i need is called
Thank you
pink44
The temperature sending unit for the gauge is located on the intake manifold near the thermostat housing, and it has one wire going to it. Near this unit the the temp sensor for the EFI control unit, which has two wires going to it.
When you say the auxilliary fan switch, I assume you mean the thermosensor which controls the electric cooling fan, which screws into the passenger side radiator tank near the bottom of the radiator.
Hope this helps.
Hope this helps.
Hello
Thank you for your help you told me what i needed to know . I could not figure it out
Their was just a hole their leaking water when i brought the car so i didn't know what went there
Thank you again
