Engine rebuild kits?
Nobody sells a complete kit for the EA82 engine. You have to buy everything individually, which generally includes an overhaul gasket set, rings, main bearings, rod bearings, an oil pump, a water pump, timing belts.
I've gotten my stuff from 1stsubaruparts.com in the past.
Whatever you do, don't go to NAPA. Their headgaskets suck, and most of their parts are more expensive than the OEM stuff is from discount places like I mentioned above.
