oddcomp Posted November 13, 2005 Share Posted November 13, 2005 according to my limited books i have on the subaru wiring /ecu it seems that the actual knock detection is done outside of the factory ecu ? and then piped into the ecu for timing control sorta like a after thought during the design process so where is the small box that listens for the signal from the knock sensor located at? anyone know where or what it looks like or if it even exsists? Quote Link to comment Share on other sites More sharing options...
All_talk Posted November 13, 2005 Share Posted November 13, 2005 I believe that the '86 and older EA82T uses an add on system like you describe, I think the control box is somewhere on the passenger side of the engine bay. I can go look at my parts car come day light. The '87+ Ea82T has the control built into the ECU. Gary Quote Link to comment Share on other sites More sharing options...
Ross Posted November 13, 2005 Share Posted November 13, 2005 Thats right, if its '86 or older it has a knock control unit in the left (in a rhd anyway, probably same side as your coil is on?) guard. You have to take the guard off! However, it does not interface with the ecu, it simply changes the voltage applied to the extra two terminals on the pickup in the distributor. Quote Link to comment Share on other sites More sharing options...
Subi81 Posted November 13, 2005 Share Posted November 13, 2005 As far as I can tell the knock control unit is located behind the glove box. Quote Link to comment Share on other sites More sharing options...
Ross Posted November 14, 2005 Share Posted November 14, 2005 As far as I can tell the knock control unit is located behind the glove box. What makes you think that? I'd have thought the RX would have it in the same place as the wagon, but maybe i'm wrong. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted November 14, 2005 Share Posted November 14, 2005 On the 83/84 is this the box in the fender well on the Left side of the car? Quote Link to comment Share on other sites More sharing options...
Ross Posted November 14, 2005 Share Posted November 14, 2005 On the 83/84 is this the box in the fender well on the Left side of the car? Yep. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 14, 2005 Share Posted November 14, 2005 ea81 and 85-86 turbos it will be under the fender. it connects entirely to the distributor Quote Link to comment Share on other sites More sharing options...
Subi81 Posted November 14, 2005 Share Posted November 14, 2005 When I looked in my 86 FSM there is a connector for the knock control and it looks like it is behind the glove box plus when I was traceing wires trying to find a short I found a black box in there bolted behind the glove box more to the right (looking at the glove box). If it is in fact located inside the fender " i guess you learn something new everyday. Could you tell me what is this gaurd that you speak of, curious? Quote Link to comment Share on other sites More sharing options...
Ross Posted November 14, 2005 Share Posted November 14, 2005 . Could you tell me what is this gaurd that you speak of, curious? Sorry, "guard" translates to "fender". Quote Link to comment Share on other sites More sharing options...
oddcomp Posted November 14, 2005 Author Share Posted November 14, 2005 want to try and use it as a knock interface for my megasquirt and edis setup hehe hmm i thought i recalled seeing a wire in the diagram running to the ecu maybe its just a signal wire to tell the ecu its knocking and to trip a check engine light if it knocks for to long Quote Link to comment Share on other sites More sharing options...
Subarian Posted November 14, 2005 Share Posted November 14, 2005 Forgive the shameless hijack, but if I understand this thread right, I can take the knock sensor off of my 86 EA82t parts car and put it on my carbureted EA82 that's getting the turbo, and then I don't need to worry about recurving the distributor? Quote Link to comment Share on other sites More sharing options...
oddcomp Posted November 15, 2005 Author Share Posted November 15, 2005 hijack away lol and umm you will need to drill and tap the hole in the block for the knock sensor and also swap the distributor over i would bet if whats been said is how it works and it infact does control the timing directly instead of the ecu doing it on the older turbo's personaly if i was going to the trouble of boosting a non boosted motor i would covert over to at least some kind of injection system either stock or in my case not so stock Quote Link to comment Share on other sites More sharing options...
