November 14, 200520 yr Problem: 94 Legacy 2WD 5-speed has a stumble between 1000 and 2000 RPM under load. Idle is smooth. Car has 96K on the clock. After 2000 RPM, everything is fine. Happens in any gear. Any ideas? Greg
November 14, 200520 yr I've been getting the same thing. I've also been getting an odd sqeak from what seems to be an injector, so I bought some fuel system cleaner. It seemed to help a bit after the drive I took the other day, but I won't be able to even really touch/drive my car until Thursday or Friday. I have some seafoam and new spark plugs, too, so I'll see if that helps. I suppose at the worst I'll have to buy a used injector.
