November 14, 200520 yr I have an '04 impreza ts and my question is, I see all the after market parts are for a wrx ( specifically intakes ) and was woondering if they will fit my car? Also clutch components like pressure plate and flywheel do they fit? any help would be appreciated Thanks -Chris
November 14, 200520 yr I have an '04 impreza ts and my question is, I see all the after market parts are for a wrx ( specifically intakes ) and was woondering if they will fit my car? Also clutch components like pressure plate and flywheel do they fit?any help would be appreciated Thanks -Chris i replied to your OTHER thread in Marketplace. (why post the same question 2 times?) Jamie
November 14, 200520 yr When it comes to flywheel clutch pressure plate, you cannot interchange with a turbo model. It works diffrently. Im sure you can find light flywheels clutches etc for 2.5 RS As for air intakes it depends....if your looking at a K&N drop in filter it should be no problem...if your looking at a short ram or something you may want to make sure by looking at fitment Hope that helps Cory
