November 20, 200520 yr Hi guys, Can you make a starter motor turn in the opposite direction. I can see on the one I have (liberty) that there are two main terminals and a smaller pin out. One of the large terminals is currently wired up. Can I swap them over? Thanks in advance Paul
November 20, 200520 yr It's possible, but depending on the design, the engagement system that slides the pinion gear into mesh with the flywheel may not work.
