yota aluminums + studs
anyone running yota alum rims. 1st you have to run the yota wheel nuts right? so the question is when i redrill rotors do i have to use yota studs or subi studs gonna work?
if they are the same taper you are okay using subaru nuts. I use subaru lugs and studs for my yota steels.
ya but these are the original alums that had the washer style wheel nuts
U will probably have to use Toyota studs, but check one of the lug nuts (Toyota washer style) on the stock Subaru stud to be sure. If the threds match then U will be fine with Subaru studs.
That's a bummer man. But U can get studs for cheep @ NAPA. They sell 'em 1@ a time, and U can get the lugs to go with 'em 2.
If U know the size/thred pitch U can order full sets w/lugs from Summit Racing.
they dont match, but i still have the Isuzu rims they are only 6" wide w/5" backspace compared to 7"w/ 4.8" backspace but less work and a bit nicer looking, but the trade off is 1" wider stance, first i have to get the bad camber angle figured out(no i dont have the 4" lift block in backwards)
toyota wheel:
Isuzu wheel:
