easy question for you
So my friends mother has a 2000 forester. She stopped up today because her front windshield washer had stopped working. Well I couldn't get that damn electrical green clip off. I tried just pulling, wiggle, and a screw driver to press in a clip (if there is a clip holding it down). I couldn't get it off, I told her I would install her new pump when she got it. How do you get this clip off, is there a "clip" that holds it in, that has to be pressed down while you are pulling up on the whole thing? once I solve this I need to know, Does the pump just slide out?
I have had mine off a few times but dont remember the details, but if you will unbolt the tank you should be able to raise it up where you can see how to take plug off. Be careful when you bolt tank back down the little hole will break easy.
