November 30, 200520 yr Subaru Legacy 1993 AWD, auuto, non-turbo When wires connected Check Engine "blinks" 33 <== what does this mean? Check engine light on + Spedometer and odometer no longer workingSmell of something hot in back of car inside and aropund back of car Replaced transmission and differential in September Where can I find the meaning ofr the code for Legacy 1993? THANKS VM
November 30, 200520 yr It is the code for the vehicle speed sensor. There are probably 2 on your car, they are on the transfer case and the transaxle. Take the car back and complain, see if they will fix it. Worth a shot! When you say "hot", is it coming from the exhaust or somwhere else?
December 2, 200520 yr check out my website for info on checking codes and other info. Your problem is probably this little guy. http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg The shaft inside the piece breaks, and the speedo no longer works. Replace that piece, reset the ecu, and everything should be good.
