December 2, 200520 yr Need to get a bottoming tap for my head bolt holes. Does anyone know what size it is? I might as well get a tap for the cam block bolts too; does anyone know what that one is as well? Sorry, I was meaning to bring the bolt with me to work so I could stop off and pick up a tap on my way home, but I forgot, so if someone could help that'd be awesome!!
December 2, 200520 yr The head bolts are 11x1.25 Good luck finding a tap for that. I gave up and bought timeserts.
December 2, 200520 yr This set has the one you want in it..... http://www.globalspec.com/FeaturedProducts/Detail/MetricScrewTool/Metric_Tap_and_Die_Set/22735/1 Cant see why it would be that hard to find a single one - a trade tool shop should be able to help you out if thats what you want.
December 3, 200520 yr Cant see why it would be that hard to find a single one - a trade tool shop should be able to help you out if thats what you want. Never did find one locally. Closest place that had them advertised and actually had them in stock when I looked about a year ago, was in the UK
