washakie Posted December 5, 2005 Share Posted December 5, 2005 Howdy folks. Glad I found this site! I have an '83 GL with an EA-81, 4wd, 4 spd, non-turbo. I have big plans for it as an off-road project car, but currently I need it for my daily drive. It's leaking oil pretty bad, so I washed the motor to help trace the leak. The disty cap did get wet, but it was bad anyway. I replaced it with a new one after the wash (#3 wasn't firing). All is well, and it runs great, it just won't idle! I don't know what to do?? Any thoughts? Link to comment Share on other sites More sharing options...
jxavierf Posted December 5, 2005 Share Posted December 5, 2005 First things first......check for vacuum leaks. The easiest way to do this is to take the air filter lid off, while running, take a rag and put it over and cover the opening to the carb.....use both hands and try to cover it completely so it is completely sealed.....listen to the idle....if the idle increases when you do this = you have a vac leak. If your car is not idling well enough to even try this, adjust the idle up using the idle screw until it settles to a comfortable, unshaky idle. Another thing......how long has it been since the fuel filter/separator was changed. Actually, before your try any of this, Seafoam the carb to clear out any grit. Link to comment Share on other sites More sharing options...
washakie Posted December 5, 2005 Author Share Posted December 5, 2005 Thanks. The story here is that this is one of those soobs, that has served many good people for many good years, with MINIMAL maintenance, but regular maintenance... i.e. oil changes. It has 200k on it now, and I'm planning on doing a major over haul in time, but now is not the time for me... I never should've stressed over the leaks, because it was running like a champ! I'll go and see if it's a vacuum leak. Thanks for the tip. I'm sure Seafoam is in order too. Link to comment Share on other sites More sharing options...
washakie Posted December 10, 2005 Author Share Posted December 10, 2005 Excellent! It was in fact a vacuum leak. All is well now. Link to comment Share on other sites More sharing options...
BlueTrain Posted December 11, 2005 Share Posted December 11, 2005 Excellent! It was in fact a vacuum leak. All is well now. just curious, but where did you happen to find the vacuum leak to be? Link to comment Share on other sites More sharing options...
