December 5, 200520 yr my brat (79) needs a radiator and exhaust (everything past the cat)... anyone have either, or ideas of options. thanks
December 5, 200520 yr i don't think the 79's have cats... at least they don't call it that... they call it a pre-muffler or something... but i don't think its a cat... anyway, this might be a fun opertunity to squeeze a few hp outa your brat... maybe a 2" stainless exhaust? and depending on where its leaking from, you might be able to fix your radiator... any good with a soldering torch? sorry but i don't have either... good luck though!
December 5, 200520 yr Author you might be able to fix did you see the signature... i'm like too many people, i can attach this to that but beyond that i'm for the most part lost. as for soldering, thats not something in the relm of talents (i've got this awsome herititary tremor)
December 5, 200520 yr It's not a cat. It is called a resonator. You don't really have to have it. You just might as well take it to a exhaust shop and have a new exhaust sytem done. That is unless you want stock. Then one of the guys here on the board may be able to help you out or point you in the right direction to find a stock exhaust system.
December 5, 200520 yr Get a custom exhaust made from a muffler slop like they said. Shouldnt cost much, $200-250 or so. You can have it made with whatever muffler you want, any style you want, a resonator or not, basically anything goes since we don't have cats... As for the radiator, order a new one or upgrade to an 80's radiator from a junkyard. (I lucked out and found one in PERFECT shape from a late 70's wagon at a junkyard)
December 5, 200520 yr i hear that Miles Fox runs a 2.5 in from the y pipe back using a glasspack as a resignator, then a straight pipe going to another glasspack in the back. he said it sounds pretty mean, i`m considering doing this too.
