subestyle18 Posted December 6, 2005 Share Posted December 6, 2005 Ive had the car for about a month. a week ago the it would only blow hot air no matter what setting or temp it was at. It was like this this morning. Left the car for ten hours. Came back started it up and with the car warmed up fully it would only blow cold air. Im guessing it has to do with the linkage to the mixer for the air but havent really done a whole lot of work on this car. So has anyone had a simalar problem. I pulled the radio but that does not allow access to the HVAC controls. Where is the mixer located is their an easy way to access it? I work at a ski area so heat is kinda a nessacity. I could see my breath the whole drive home tonight. Nothing like working out side in 20 degree weather only to have to drive and hour and a half home with no heat. Any help would be great. Thanks David Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted December 6, 2005 Share Posted December 6, 2005 Not sure on your model, but usually, you can see a cable going to the ductwork under the dash by the floor. Move your temp control back and forth to see if there's anything moving. Usually, the flap is located around the center of the ducting, very close to where the heater core would be. Quote Link to comment Share on other sites More sharing options...
subieman Posted December 6, 2005 Share Posted December 6, 2005 Check under the hood, maybe the previous owner bypassed the heater core. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 6, 2005 Share Posted December 6, 2005 There's no bypass on the heater core. Engine coolant always is circulating. If you remove the glove box, you should be able to see where the cable goes to the box and flapper door. The little end probably broke off. Quote Link to comment Share on other sites More sharing options...
subieman Posted December 6, 2005 Share Posted December 6, 2005 There's no bypass on the heater core. Engine coolant always is circulating. If you remove the glove box, you should be able to see where the cable goes to the box and flapper door. The little end probably broke off. It is possible to bypass the heater core. I have done it when my heatercore sprung a leak. Just check it out. Quote Link to comment Share on other sites More sharing options...
subestyle18 Posted December 6, 2005 Author Share Posted December 6, 2005 Since the heat worked for the first three weeks im guessing its not bypassed, so i'll pull the glove box. Theirs just so much plastic in these newer cars takes forever just to get to the broken part. I guess im too used to my 83. Thanks for the help. David Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 7, 2005 Share Posted December 7, 2005 It is possible to bypass the heater core. I have done it when my heatercore sprung a leak. Just check it out. From the factory it is does not have a coolant bypass valve like some manufacturers use to control heating. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 7, 2005 Share Posted December 7, 2005 Since the heat worked for the first three weeks im guessing its not bypassed, so i'll pull the glove box. Theirs just so much plastic in these newer cars takes forever just to get to the broken part. I guess im too used to my 83. Thanks for the help. David The plastic stuff on the legacy isn't too bad. Try some of the newer-newer cars. To get the glove box off, there's two screws underneath. It's a piece of cake. Quote Link to comment Share on other sites More sharing options...
subestyle18 Posted December 8, 2005 Author Share Posted December 8, 2005 Got down under there and took a look. The cable end had sliped off the mixer. Put it back on heat works fine. Thanks for the help. How it got switched to cold when it was disconnected i'll never know. David Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 8, 2005 Share Posted December 8, 2005 Glad it was an easy fix Quote Link to comment Share on other sites More sharing options...
