December 8, 200520 yr My 1993 impreza L wont start. It started with the Check engine light coming on. The fan would run as soon as the key was turned. Coolant sensor was replaced. cleared up the fan problem. Still no joy in starting. There is puls e in the injectors. and a double spark from the spark plugs. the crank shaft sensor was replaced with a camshaft sensor minus the sleeve would this have a bearing on it not starting also how about changing the ignition module? any help gratly appreciated. Dave Morris
December 8, 200520 yr So they put a cam sensor in place of the crank sensor? I suppose that would work, but I don't know if I'd recommend it. Have you tried checking for any additional codes? Have you reset the ECU?
December 9, 200520 yr Author Hi Josh I also replaced the PCV valve and the battery has been disconected. I ordered a new crank sensor. And when the weather gets better I will replace the sensor and try it again. Thanks Dave
December 10, 200520 yr Have you checked the compression of all the cylinders? One of the timing belts may have broken.
December 18, 200520 yr Author Weather was fine. Replacedthe CRANKshaft sensor with a subaru part.and replaced the camshaft sensor with the one that was used in the Crankshaft sensor. Still have a good spark and fuel is ok. still not starting. there is a popping sound like it almost wants to start when the key is turned off. Commpresion has not been checked hope to do that today. Any help greatly appreciated.
December 18, 200520 yr I'd double check to make sure the timing belt is installed correctly. It may be firing, but at the wrong time.
December 31, 200520 yr Author The timing is at 10 degrees if the timging mark is correct a rather small notch in crank barely noticeable. The spark plug wires were replaced. Atiming light was used and my mechanic said there seemed to be two sparks he checked the wires and he thought his timing light was broken that was when the wires were changed. He said that the timing should be at 10 degrees. He is also stumped Any Help appreciated.
December 31, 200520 yr Have you checked the compression of all the cylinders? One of the timing belts may have broken. Hey there Cougar, I can tell you're old school by the duality of your timing belt remark. But I agree, broken/slipped belt could be a cause...If you are getting spark and fuel, and it won’t start, either the ECU is being dumb, or the VALVE (not spark/ignition) timing is wrong/not working. It's easy to check for the presence of a belt...just 3 10mms holding the end cover on.
December 31, 200520 yr These engines use a wasted-spark type ignition, so there will be four sparks per revolution on a 4 cylinder engine, with each spark plug firing once per revolution, somewhere near top dead center on the compression and exhaust strokes. So it may seem that there are twice as many sparks as are necessary, which there are. There really is no setting of the timing on these engines. A properly installed timing belt is all that is required for proper engine timing. The cam and crank position sensors and the ECU do the rest. I agree with the others that yours does sound like a timing problem. I would pull the timing covers and verify the timing of the timing belt. When was the last time it was changed? How many miles and years ago?
December 31, 200520 yr Author The timing belt was changed at about 60000 miles. Thanks for your replies. And have a happy new year
January 2, 200620 yr Author Timing belt was changed at about 60000 miles about 3 years ago. I replaced the spark plug wires still no go.
January 2, 200620 yr You said the injectors were pulsing, but are you sure fuel is getting to the cylinders? Try some starting fluid if you haven't, just remove the filter and spray it in to the duct while someone cranks it. If that doesn't fire, then cam timing must be way off of that sensor is probably no good. I would think the ignition module is working if you have spark.
January 2, 200620 yr Starting fluid whould have been my first shot. I know a lot of folks don't like to use it but a short squirt tells you fuel problems in three seconds.
January 2, 200620 yr A good idea it is, but be very careful, if the timing is off, putting a flammable liquid into the intake can be very "exciting".
February 2, 200620 yr Author Guys Finally was able to get around to fixing the car. You were right it was a timing problem. I had to trplace the timing belt auto tensioner. Realign the timing belts as they are at 90 degrees as opposed to being 180 degress in normal cars. Put cover back on and the car started. Once again thats to all of you for your help. Regards Dave Morris
