Mark 86GL Posted December 13, 2005 Share Posted December 13, 2005 Hi, I'm new to the forum, and have an 86GL with 75,000 original miles on it. After putting some work into the car, it runs great. I have one issue that I need to fix before it will pass inspection in PA. The EGR light came on like it should after 60,000 miles, but I haven't been able to turn it off yet. I understand that there's is a connector under the fusebox that should have green and blue wires reversed in order to reset the EGL light. I've looked a couple of times but this connector is not obvious to me. There are several relays with four wires, but nothing with just two wires and banana plus. Can someone please tell me specifically where this connector is, maybe using "landmarks" in this area under the dash? Thanks a bunch for the help! Link to comment Share on other sites More sharing options...
Subarian Posted December 13, 2005 Share Posted December 13, 2005 It's been a while since I did this (I have 253,000 on mine) but I remember it being up high and to the left under the dash, above the trim on the left side of the footwell. Hope this helps. Link to comment Share on other sites More sharing options...
stephenw22 Posted December 14, 2005 Share Posted December 14, 2005 I just pulled the dash and then disconnected the plug going to the light. Took me about 30 min. Link to comment Share on other sites More sharing options...
