Surfdougyfresh Posted December 14, 2005 Share Posted December 14, 2005 The front right end of my '98 outback gives a duh,duh,duh when going over even the smallest bumps in the road. I think it might be the shock mount, but don't want to pull everything apart to find out the thing is fine. Can anyone describe the symptoms of a broken shock mount? I've had it up on a 2 post lift and everything else seems tight underneath. Thanks guys... Link to comment Share on other sites More sharing options...
Legacy777 Posted December 14, 2005 Share Posted December 14, 2005 If you've had it up on a lift and felt everything in the suspension, and it's tight....the mount is probably ok. Link to comment Share on other sites More sharing options...
a97obw Posted December 16, 2005 Share Posted December 16, 2005 The front right end of my '98 outback gives a duh,duh,duh when going over... "Zis is KAOS! Ve don't duh duh duh here!" (Bernie Koppel as Head of Kaos from Get Smart) In my 97 Outback wagon it was the front left strut. Replaced both front struts and the upper mounts, the mounts were probably ok, but the strut had a definite "dead spot" in it where there was no resistance in up/down motion for about an inch or so. No more noise. That's my bet. Link to comment Share on other sites More sharing options...
