Check Engine Light
Ok well a friend of mine has a 1995 impreza and the check engine light is on. Now i wanted to know is there anyway to get the codes from the car via the radio, she went up to autozone to have the codes pulled but they said her car was to old.
the radio might sing the blues for you but i dont think it will "talk" the codes for you,do a search for codes you will find all you want.
ok well looked up about the connectors and it says that the 1995 Impreza has an OBDII connection port. I found that you can buy a device to pull the codes and everything but what i want to know is, does Advance auto parts or auto zone or some auto place have the machines to pull the codes because when my friend went up there they told her that they couldn't do it because it was to old but i believe that they should be able to.
they are right ,ill try to find the instructions for you.
