Subaru Jim Maple Ridge Posted December 20, 2005 Share Posted December 20, 2005 I have a '90 SW that floats on the idle once warmed up. Code indicates IAC but the module tests 9 ohms. It is, however, a two pin connector. The harness has three pins. The other two parts cars here both have a three pin module, which looks like a bi-polar, rotating valve. The faulty one appears to be more like a solenoid, plunger type. Has someone replaced it with the wrong module, or are they interchangable? Thanks, Jim. Link to comment Share on other sites More sharing options...
Legacy777 Posted December 20, 2005 Share Posted December 20, 2005 Is your 90 SW an automatic or manual trans? The automatics got the 3-pin rotary IAC valve. the manual trans cars got the 2-pin recipricating valve. If you have the correct valve, you may want to try getting a used one from a junkyard and swapping it in. Have you tried clearing the codes and seeing if the IAC code comes back? Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted December 20, 2005 Author Share Posted December 20, 2005 The parts cars are autos and this car is a standard. I have the valve off. It looks as if the contacts were corroded and the valve was stuck closed.It is all cleaned up, I just wasn't going to put it back on if it wasn't the right one. All of these cars have a lot of history before I ever see them, so in some cases there is a lot of correcting to do. Quite often the only thing wrong with a car is what other people have done to it. Thanks for the help. Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted December 21, 2005 Author Share Posted December 21, 2005 Problem solved. Thanks again Josh. Link to comment Share on other sites More sharing options...
Legacy777 Posted December 25, 2005 Share Posted December 25, 2005 Glad you got it fixed. Link to comment Share on other sites More sharing options...
