December 20, 200520 yr I have a '90 SW that floats on the idle once warmed up. Code indicates IAC but the module tests 9 ohms. It is, however, a two pin connector. The harness has three pins. The other two parts cars here both have a three pin module, which looks like a bi-polar, rotating valve. The faulty one appears to be more like a solenoid, plunger type. Has someone replaced it with the wrong module, or are they interchangable? Thanks, Jim.
December 20, 200520 yr Is your 90 SW an automatic or manual trans? The automatics got the 3-pin rotary IAC valve. the manual trans cars got the 2-pin recipricating valve. If you have the correct valve, you may want to try getting a used one from a junkyard and swapping it in. Have you tried clearing the codes and seeing if the IAC code comes back?
December 20, 200520 yr Author The parts cars are autos and this car is a standard. I have the valve off. It looks as if the contacts were corroded and the valve was stuck closed.It is all cleaned up, I just wasn't going to put it back on if it wasn't the right one. All of these cars have a lot of history before I ever see them, so in some cases there is a lot of correcting to do. Quite often the only thing wrong with a car is what other people have done to it. Thanks for the help.
