Alex GL-10 Posted December 21, 2005 Share Posted December 21, 2005 Are the axles for an automatic GL-10 AWD turbo Wagon the same as the axles for a manual GL-10 AWD turbo Wagon of the same year? Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 21, 2005 Share Posted December 21, 2005 I know my auto matic turbo axles are the same as a 5spd dual range...with 3.9 gearing.. Quote Link to comment Share on other sites More sharing options...
Alex GL-10 Posted December 21, 2005 Author Share Posted December 21, 2005 I know my auto matic turbo axles are the same as a 5spd dual range...with 3.9 gearing.. the 5spd is single range. with 3.9 gearing the auto has 3.7 gearing. Would the axles still be the same? Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted December 21, 2005 Share Posted December 21, 2005 FOUR SPEED auto and all manual turbo transmissions take the same axles. So, if your shifter markings say "P R N D 3 2," the turbo manual trans axle will work. If it says "P R N D 2 1," it'll take the same axle as ANY nonturbo car, but not the one from a turbo 5-speed. Quote Link to comment Share on other sites More sharing options...
Alex GL-10 Posted December 21, 2005 Author Share Posted December 21, 2005 FOUR SPEED auto and all manual turbo transmissions take the same axles. So, if your shifter markings say "P R N D 3 2," the turbo manual trans axle will work. If it says "P R N D 2 1," it'll take the same axle as ANY nonturbo car, but not the one from a turbo 5-speed. Thanks for the help. Mine is a four speed so I guess they will work. Quote Link to comment Share on other sites More sharing options...
