December 23, 200520 yr Hey all, Just did a switch from VW. I was lookig for a new car, an this 93 4WD Legacy L 5 speed jumped out at me. A friend of mine who is a mechanic at the dealer manage to get a trade in put aside and I bought it for 500$, and I negociated a brand new clutch, pressure plate and clutch bearing at cost, as well as a new battery for free. The very bad: Needs a clutch yesterday The power steering tubes ar rusted and leaking (Will be done together next week) The bad: Oil pump gasket starting to go (Will be done this summer at the same time as timing belt) The annoying: A little too much rust (spot, only 2 wholes, 1 inch and 2 inches) (will be fixed locally next summer) Timing belt so so (this summer) Rear brakes need to be done this summer Rear wiper not working, seems jammed, I can hear the relay click though. Will look at it next week. The worriesome Check engine light came on when I installed the new battery. I guess there was not enough voltage on the old one to trigger codes. Will check it out next week. The good: Floor, body in excellent shape. Nice handling, straight, even when braking hard Clean interior. Solid shocks, front brakes, engine and tranny Any advice on the above problems, as well as potential things to look for and how to care ? Expect to see me often ! Cheers JF
December 25, 200520 yr Check out my site www.surrealmirage.com/subaru There's info in the notes & tips section on how to pull the codes from the ECU. Also, check out www.bbs.legacycentral.org there's a lot of good info on the first gen legacies.
