January 7, 200620 yr My wifes drivers side fog light was smashed, has anyone replaced the factory lights with something other than the OEM? They are big $$$$$$.
January 7, 200620 yr Since you posted twice, does that mean that both are smashed? The Outback lights aren't easy to replace with aftermarket because of the size. I have seen some OEM on ebay for between $89 and $129.
January 7, 200620 yr less than $100 per side for a replacement fog lamp assy (OEM) go here: https://www.subarugenuineparts.com/oe_parts_cat.html drill down in the body catalog to model and year, enter key word: fog each assy is $91.67 OEM, plug and play, no messing with wiring or custom mounting brackets. hope this helps somewhat. Jamie Thomas email: Jamie at chaplins.com http://www.subarugenuineparts.com *************************** http://www.subiegal.com
