ejmartin Posted January 9, 2006 Share Posted January 9, 2006 I have a 86 loyal wagon and I'm planning on replacing my right front axle tomorrow. I was wondering if it's as simple as taking off the wheel nut, popping out the ball joint and sliding the axle out of the trans.. then reverse the process? Is there anything helpful I should know before starting or if theres anything else I should need or replace while in there?? Thanks in advance!! Elliott in Idaho Link to comment Share on other sites More sharing options...
