91 loyale brake light problems
Greetings
I am recently noticed that my little brake light warning light flashes on, when i apply the brakes. I have checked all the lights and they work fine.. Is this just from old age or am I to suspect a huge problem coming on.
Thanks for the help
John
Make sure that you have enough fluid in your master cylinder, you may be low, which is either a leak, or most likely you're pads are getting thin, and they need replacing, which if they do, we'll hit the junkyards and we can get some rear disc parts and do the rear disc swap at the same time.
It could also be that one of your brake lights are out, have Kim stand behind the car when you push the brakes, you might have a bulb out then.
Eh... The lights arent out. I have checked that out over and over. Maybe it is my brakes..
thanks
John
There's a float in the reservoir on the master cylinder. When the level drops too low, it brings on the light on your dash. That's the first place to look.
